Beolab 3500 sound troubles
Hi Steve, thx for the swift reply.
Type:1601
Serial: 18673469
Item:1160111
Sw: 2.0
Thx & KR Stefan
Thanks Stefan,
This is a mk.1 Beolab 3500, so a specially wired cable is needed for this speaker (please choose the mk.1 cable option here):
Thank you for your assistance. I actually habe a comparable cable (7pin) is it still likely that your cable will solche the issue?
Could you provide also a shorter cable (I would like to fix the bluetooth device right in the Back of the beolab.
Thx and KR Stefan
Hi Stefan,
This cable wiring ins unique, no other 5 pin or 7 pin cable will work unless it is specifically wired for Beolab 3500 mk.1.  The cable is the cause of the issues that you reported in your post.
You can see the correct cable and the length options available in the link that I posted above.
Kind regards, Steve.
Hi Stefan,
I have the same issue with my BEOLAB 3500,  ticking and noise with or without the MCL cable connected after selecting the MCL input.
Did you ever found the solution?
Many thanks in advance,
Regards
Nico
Nico,
In fast the issue was a wrong cable. I got in touch with Steve directly to clarify what I need and they shipped it. My 3500 nie works perfectly with a bluetooth receiver.
Cheers Stefan
Hi Stefan,
Glad to hear that all is working well!
