Beolab 3500 sound troubles
Hey guys,
just received a BL3500, but there seams to be a strange problem, speakers has clicking/ticking sounds.
any help would be greatly appreciated.
Anyone have any ideas?
Where did you plug BL3500 ?
I’ve have only tried in MCL mode connect to air port express, as I don’t have master link.
That will not work.
Contact Steve at Soundsheavenly. I think he can help you with the connections.
I got the Mk1 cable from sound heavenly.
its the speakers them selves that are the problem.
here is a sound clip with nothing plugged in and in MCL mode.
Anyone??
Hi Dino,
I am sorry to hear that you are having problems.  Please can you email me directly with the order reference code from your cable purchase and also the serial number of your speaker?  I can then look into this further for you.
Kind regards, Steve.
