Beolab 3500 sound troubles
Just a quick update with an apology - the iPod (minijack) to Beolab 2000 cable mentioned previously is unfortunately no longer available.  I do still have the minijack to Beolab 3500 cables though.
Kind regards, Steve.
What cable do you bought. I have 3 pcs. Beolab 3500, all of then ticking an d humming noise in MCL mode, also without any cable connected. Thanks Per
Hi Per,
If the speaker tick without any cable connected then you appear to have a speaker issue, this won't be caused by the cable......
From vague memory I also think that my BeoLab 3500 made humming and tick noises in MCL mode while not being connected to anything. I think this is normal. The cable solution did not solve what I was trying to achieve so I opted for a different setup when using it as center speaker and connected to the B&O link system at the same time.
Hi Stefan,
Welcome to Beoworld!  Sorry to hear that you are having problems.  Please can you tell me the serial number printed on the sticker at the back of your Beolab 3500 speaker?
I can then confirm which version of speaker you have and advise how to resolve the issue.
Hi Steve, thx for the swift reply.
Type:1601
Serial: 18673469
Item:1160111
Sw: 2.0
Thx & KR Stefan
