Hi all,
just got my 3500 mk1 back out after 12 years of storage. I am getting the following problem symptoms:
1. Power up standalone - no problem
2. Not connected ...using beo4 commands menu/0/4/go - quiet ticking sounds from both ends “Tchh tick tick tick tchh tick tick tick” repetitively
3. Plugin din7 to 3.5mm jack.(no device connected) - audible humm like quiet feedback
4. connect 3.5mm jack into any pc/iPad//iPhone - loud feedback overrides the sounds from the device.
Any ideas of cause and/ or solutions much appreciated.
thanks
