Bit of a strange one which Im hoping someone may be able to offer some practical advice on as weve moved recently and the layout of the new house has caused a few problems.
Current set up is Beolab1s as main speaker fed through a denton x3400. Previously I was using lab 6000s as which worked well but the layout of the new house means there is no way to physically mount speakers on the rear wall due to a slightly offset open staircase running up it!.
The original layout of the room had a wall between it and the stair case but this was removed to 'open plan' it so there is a beam running across behind the listening area and parallel to the staircase.
I was going down the route of looking for ceiling mounted speakers for rears but Im wondering if a bola 3500 could be used if Im a little createive.
Effectively Id need to remove the amp and power circuitry and run it passive powered by the AVR unit, I could then potentially mount it to the rear of the beam (facing away from the listening area so it reflects off the rear wall.
Q: How easy would it be to remove the amp/power circuits and make it passive, or could these just be unplugged, and do you think that this would work?
The main benefits if this could work is that it would keep the look of the system and save sourcing ceiling speakers.
