Hi
I have followed this forum from a distance over some time.
I have an old BL3500 Mark I I would like set up in my kitchen and connect to the BeoSound system in the living room, but connecting with cables is rather difficult.
I have seen different posts from Keith Saunders and Steve at Sounds Heavenly stating the opposite:
Steve from 2019:
All versions of Beolab 3500 should work with Beolink Wireless 1 when connected with a Masterlink cable.
In order to use the speaker via a Powerlink cable, it must be a mk2 version (DIN socket marked as Powerlink) AND software level at 3.1 or above.
Keith from before 2014:
First the Beolab 3500 has two variations:-
- LCS9000 later to become the Beolab 3500 Mark I which has MCL (Master Control Link) and ML (Masterlink) but NOT Powerlink and has a latest software version of 2.1. You can see the FAQ HERE on how to upgrade to version 2.1 software. The LCS9000 and the Beolab 3500 Mark I CANNOT be used with the Beolink Wireless
B&O product support claims that my setup should work, but I am still not sure.
Can someone clarify before I buy a second hand BLW1; will this setup work?
Jesper
