beolab 3500
Dear friends
I have a beo centre 2300 and have just aquired a beolab 3500, which i would like to have in a second
room. I have been told that this is possible, I have cabled this up from the beo centre to a beo link
converter from the aux socket on the 2300 to the aux socket on the converter and a master link
cable to the beolab 3500. Using my beo4 controler, but all i can get on my beolab 3500 is a display
saying cd. Could anybody help me i don,t have a manual for the 3500 or the beo4 controler.
I am pulling my hair out.
Many thanks
             Phil Dale
I think you have to add a full (8-cord) Powerlink cable between the 2300 and converter.
Is the converter type 1611?
 /Ola
Quite correct. You will need a MK2 fully wired powerlink cable between the 2300 and the converter.
Connect the 2300 and 3500 to the mains before you connect converter to mains and the 1611 will self configure.
From memory, 2300 in option 0 and 3500 option 4 should get you working.
The manual is on site for silver and gold members.
Ok all, feeling a little stupid here..............................
I've just bought a Beosound 4 on ebay, as I thought I would need it for my new system - see this link
I see no reason why the AUX connection should not be used as input and output simultaneously, e.g. by connecting the input pins to your mac-mini and connecting the output pins to some other system. Not sure if the AUX output is driven while you play the source connected to the AUX input (i.e. your mac-mini) but it should be when listening to CD or RADIO. However my Ouverture does so!
