Beolab 3 vs. Beolab 14 / Beoplay S8, or M3 / S3
Since my Beolab 4s are failing, and I'm a bit reluctant to buy a replacement set because all of them are doomed to fail, I'm on the lookout for some new pc speakers.
They are to be used as main speakers while gaming, and since the computer is near the kitchen, music is occasionally played as well, sometimes at higher volumes.
Was looking into a set of Beolab 3s, but they are a bit over budget for what I'm willing to spend for a set of computer speakers. If I was to get a set of Lab3s, I'd hang them on the wall as rear speakers in the main room (with Lab 9s as fronts).
Anyone ever compare them to the Beoplay S8 set? Not really a pc speaker set, but I could image them installed around the computer.
Was looking at the more portable line-up as well (M3/S3 speakers), but manually powering up two separate speakers seems too much a hassle... Not sure if that's the route to go..
Any suggestions?
I have a pair of Beoplay S3 next to my Mac. They may lack a little detail/subtlety, but are surprisingly robust. Connect by wire or BT - beware of latency, if that’s important to your listening experience. Depending on where you live, can be had inexpensively.
Thanks for sharing your experience. Is there any delay/lag when connected through wires? Is that through the 3.5mm jack, or via usb?
Is there autosense functionality, or do you have to switch them on and off manually (twice)?
No delay when wired.  I've used 3.5mm for testing purposes.  Have never tried usb; I should.  My standard configuration is BT.  Makes no difference when playing music, of course, and I just tested BT with a movie on the Mac to check the latency.  To my surprise, latency is just about non-existent.  I remember that BT latency was very much apparent when I was fiddling around with a MIDI keyboard.
Note: I've never been able to stereo-pair the two speakers when cabled, only wireless.  When daisy-chained together, the second speaker duplicates the first.
HEY BEOWORLD:  Does anyone know how to make a stereo pair of two Beoplay S3s, when using 3.5mm jack from computer to 1st speaker, and 3.5 daisy-chain to the second?
IIRC, there's a stand-by mode, which implies autosense.  That said, I leave them on all the time.  It's a minimal power draw, iirc.
I still have a splitting cable from my BeoLab 4s, it takes a stereo 3.5mm connection and splits it into L and R channels. So I guess both can be set to act as daisy chained this way.
Not a fan of leaving them on all the time. Isn't there always a silent noise even if nothing is playing?
No hiss, no hum.
As a follow-up, I dug up this information emailed to me by B&O Play support:
” You can switch between the two standby power modes by double pressing Image (the multibutton). In high power standby, BeoPlay S3 will have sense on all inputs and can wake up, and the product indicator will signal an action. This is also the default setting. In low power standby, the speaker will not have Bluetooth or input sense and there will be no product indicator signals.”
Hope this helps.
I have had experience with the S3s as well and I would highly recommend them for PC speakers. I think they would be as good or better than your BL4s.
Interesting.
I'm not the biggest fan of their design though.
Is the M3 actually the successor of the S3? Or is it inferior?
I decided on getting a set of M3 speakers. Should be as good as the S3 I guess. + has airplay so I can use them on other occasions too for playing music in sync with my other speakers.
