Hello,
One of my Beolab 3 speakers recently stopped working. The light no longer comes on, and no sound comes out. The other speaker works just fine. I switched the power cables to check if it was that - it didn't work with the other speaker's cable either (and the other speaker worked just fine after switching cables). What should I do?
After reading other posts - I see it could be a blown fuse. I do not have the tools nor the capability to diagnose or fix said problem. Any other suggestions? I'm not sure what to do.
Thanks,
Simon
