I’m considering buying a pair of Beolab 3’s and need some help with connection options.
My music source will be locally stored FLAC files on a NAS drive.
Currently I’m using
- Phone as controller (using app Hi-Fi Cast)
- Google Chromecast Audio
- taking the (little known) OPTICAL output from the Chromecast Audio
- into a Musical Fidelity Amp that has an optical input and high grade DAC
- then into passive speakers
Questions
- With Beolab 3’s will the Chromecast still be the best option for me?
o Alternatives if not?
- Assuming using Chromecast are we looking at Chromecast to DAC to Playmaker? (Do we really need Playmaker?)
o Or is there a way that the Beolab 3’s will take a digital input (ie optical) without the need for a DAC?
o I could use the Chromecast’s built in DAC/Jack/Phono out but it’s not high quality – I’d really like it if we could bypass the need for a DAC altogether, else I’m looking at extra expense on a decent DAC
- Would the RJ45 on the Playmaker be of use at all here?
- Also I intend using a B&W PV1D sub – how to connect that in also?
Many thanks
