KingOfSnake wrote:
As far as i recall the earlier stand poles did not have a screw thread and could not be detached fromthe bases, unlike later models.
Okay, in the BL3 Service Manual the tube appears to be detached from the bottom plate. However there don't appear to be any screws for fastening. Is it possible that the tubes are merely plugged into the bottom plate? Or are the tubes perhaps threaded?
The issue is transportation. Is it safe to lay the speaker+stand combination down for transportation without damaging the bottom cover plate? (Tugged in, of course.) If so, there is no need to dismantle them.
