Hello dear B&O fans,
I need your advice.
I have a used BL2000 that works perfectly fine with my BS9000 over a ML Cable.
I am trying to use it in the following configuration:
Bluetooth over Datalink adapter to the A.AUX entry of the Beolink Converter. Beolink Converter 1614 (SAME AS 1611?) to BL2000 over the ML cable.
On the Beo4, I added a A.Aux entry in the list. I can push whatever button I want, the light on the BL2000 stays on red.
What am I missing?
Best regards from Switzerland
François
