Posted March 24, 2010 at 17:47 GMT
Thanks to the generosity of Graham, we now have the
Thanks Graham, and thanks Peter.🙂
thanks for posting this. I still can't figure out how to remove the front grills. Based on the service manual they look like they just pop off. I've tried this numerous times with no success. Any hints on how to remove the front speaker grills? Mine are bent inwards and I want to remove them to bend them back out.
Is your second first prize already broken? 😕
Thanks very much indeed for uploading this manual, I was desperately looking for this one!!🙂
Why is the pdf locked for printing?
Hi, to get the speaker grills off, slide a credit card between the bottom of the grill and the main part of the black body. Gently twist the card, this will cause the grill to slide upwards, once it's at a certain height it can be pulled off.
Regards,
Cal
