Beolab 18 + beolab 11
Is beolab 18 + beolab11 a good association for music?
I think the BeoLab 18's will overpower the 11 and you'll notice little difference.
You really need a BeoLab 2 or a BeoLab 19. ๐
Lee
I canโt see the BL11 adding anything to BL18s. If you need more bass BL19 is the way to go. Thatโs what I have.
Ok.How do you connect beolab 19 with old beosystem like beocenter 9300.
If you're using an old BeoCenter 9300 you're wasting your money on BeoLab 18's.. The 18's are really for a higher level of "digital"...
Get a pair of BeoLab 8000's and a BeoLab 2 and save yourself a lot of money. These will sound just fine with a 9300. ๐
I was owned a beocenter 9300 and beolab 3. One day the ir sensor of the beocenter was down and impossible to repai (no more piece on b&o). So i bought a beosound moment but after i was fed up because it worked bad. So i sell all my b&o and buy traditionnal hifi ( bw 702 s2 and rotel ra 1572.Now the beo sound lack to me and i am thinking to sell my traditionnal hifi and buy again b&o.I think i will buy a beocenter 9300. The most beautifull b&o system for me.two entry is good to. I will use an airport express on aux fir digital music.The question is wich speaker.I hesitate beolab 8000 (with or without bl2), beolab 3, beolab 9, beolab 5 (too big maybee) or bl18.What do you think?
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
