Beolab 18 are coming... But is it a suitable place for them?
Good evening everyone! I'm planning to buy beolab 18 and put it in this room. However there is a problem-this room has high ceilings. I tried it with my beoplay A9 and sound bounces right and forth(in a bad way🙂). I was listening it sitting on the sofa- the A9 was on the opposite side of the room. Especially bass was sort of overloaded and bounced a lot.
What can I do in this room to decrease the level of reverberation?
Attaching links -photos of the room. Sorry, didn't understand how to attach photos directly on the thread :(
https://ibb.co/095BMG9
https://ibb.co/7zFYpZ7
P.S. the fountain is not made from stone - this is some sort of foam plastic.
Thank you very much for your attention to this thread!
simplest is to try different placement and figure where the bass gets trapped and amplified the most.
next thing might be to tune it in such a way that it bothers you least.
third, get a bigger rug/carpet for the space.
I personally don't see any issues that would hinder bl18's. :)
thanks for the advice, Miki! Yeah, maybe that beolab 18s scanning technology will fix this! Actually I'm planning to setup them near the sofa - left and right. Maybe It'll be better sounding experience than beoplay A9s placement
Iam not sure what you mean by scanning technology? They’re not “smart” speakers. My advice would also hold up for the A9. But if you absolutely had to have it in that place an rug would take out atleast the reflection from the floor and to the floor(if it’s a fairly thick one)
I won't sell A9, if you're meaning this :) It will be in another room. Wanna start my multiroom collection. Also thinking between BL 18 and BL 17 :)
I think the 18s would be fine in this space.  The difference between this and the A9 is that the A9 is also on a natural backward leaning angle.
Are you close to a B&O dealer - could they come to give you a home demo?
If you're considering the 18 and 17, in time you might add a BL 19 subwoofer which you can place in a corner or wherever you want.
What are you planning to run them with? A BeoSound Core? or do you have something already
That’s what i thought, but i meant that if you put the a9 in a different place in the same room it can sound different to where you sit. Not all places in the same room give the same reflections to where you sit. Iam still not sure what you meant by scanning technology? As the 18’s or 17’s don’t do that. Only 50’s and 90’s have that ability (or the new A9 mk4 but you haven’t mentioned that before)
Yeah, I've contacted them and I'll do a home demo in the nearest future.
Yeah, with a beosound core. As for now, I have only A9 from B&O :)
Oh, I'll try that, thanks! Maybe I'll put it near the windows so it won't sound directly to the sofa and a corner there.
Oh, I messed up with scanning, you are right! 50s and 90s are the dream. Some day ... :)
I have A9 mk2
Btw Miki, nice youtube channel , I enjoyed watching 2 beotalks with John from B&O Manchester!
As I know you heard a lot of B&O stuff, What would you recommend me to buy - 17 or 18? I love the design of 18 but I heard a lot of good words about 17s and they are cheaper. But I am not sure about the look of the 17s. I think they are not spectacular in terms of design. It easily could be B&W and other guys, you know what I mean? Maybe I am wrong and it has  B&O design genes in it. And the design of 18s is already iconic because of 8000
18's have acoustic lens, look smart and sound superb. Would highly recommend a sub to go with them though. Adds to the cost but also adds a superios sound thats to die for.
Then again, an 18/19 combo is getting close to the cost of Beolab 20, so perhaps consider them too!
