BeoLab 17 reviews wanted
The BeoLab 17 is a gem, that does not get quite the attention, that the BL18 does.
There are only few reviews out there at the time being.
One of them was posted in the Geoff Martin blog:
http://www.tonmeister.ca/wordpress/2014/02/05/bang-olufsen-beolab-17-reviews/
Would be nice to collect some more (or the links) in this thread.
So feel free if you come across some out there.
If you are the owner of a pair of the BL17, this could be the place for your own impressions.
Greetings Millemissen
I was just wondering if anyone has a combo Beolab 17 + Beolab 19 subwoofer?
Curious how this sounds compared with a pair of Beolab 18s without a sub? 😮
currently my set up is a beovision 11  with beolab18 and a bl2,  I have ordered the bl17 for rears expect delivery jan 2015. I kept the bl 2 from when I had my beovision 10
will let you know what I think after installed
malcolm
Many thanks Malcolm - much appreciated!
Roman
I don't have the combo but did do a comparison at the store. The BL17+BL19 did sound better than just the BL18 in my opinion. The BL18 lacks bass and needs the BL19. I was really impressed with the BL17 overall, even though for my taste I found it a bit bright for stereo music. For cinema though it seems quite good.
I'm put off by the fact that it resembles a iMac PC...
Visually they are not comparable, but that was not the goal - so it is good we have a choice. Plus additional BL17 option with black aluminum body as of recent.
Thanx rxcohen for your impressions, I am looking for a bright sounding speaker set however not without bass (I listen to electronic music quite frequently). Also, the purpose will be a combo of Deezer streaming/iTunes and home cinema.
The beolab 17s definitely have bass, i was pleasantly surprised how deep the bass was on certain music i listen to when i had them.
to be honest they really are a lovely sounding speaker, i actually prefer the look of them in black.
The bass is good on the BL17, but the BL19 really makes a real difference. The same goes for the BL19 with BL18. I posted elsewhere the BL19 not only adds bass, but improves the performance of the other speakers above 120Hz. I just purchased the BL19 this week and added it to my 11-55 and BL1 setup. The speech now is much clearer when watching films.
For electronic music i think you would be very happy with the BL17 and BL19 combo, more so than just the BL18.
I have too disagree as the music i listen to range from r'n'b, raggae, hip-hop and the 17s excelled at that. I'm sure with the beolab19 sub it sounds even better but in the time i had them they provided ample bass with the music i listened to with them.
