Beolab 17 eol - will there be an alternative for a 5.1 config?
Hi Mikidia Currently I have the Bl6000 as front and no rear. My idea was to use the bl17 as rear because the can be wireless connected. Is that smart ?Well you can still get them for now. Although they are eol, but i you did they would be front speakers for your scenario and you could ditch the bl11 and the bl17’s outperform those on their own.
There are not so many choices these day if you want new speakers. The BL17 are great speakers and if you can justify the looks I would put them in the front with no doubt.
If you go used, BL3 are one of the best surround speakers in terms of size, placement options and price. Even they will outperform the BL6000.
I have a pair BL3 in the back and BL4 as hights. Which brings you to an other option, BL4 as ceiling speaker as there is a cailing mount available as well. As speakers on floor level they are the least attractive and performing speakers from my point of view of all BL active speakers.
An underrated option is to go with two Beolab 7.4, they are quite powerfull and on the level of the BL3 and they are quite cheap (in the 100 Euro ball park and sometimes they come with a Beovision 7-32 free of charge..), may be the best bang for the buck.
