BeoLab 17 and WiSa
Hello,
Are there any WiSa compatible TVs that will work with the BeoLab 17s? Where I can get almost the same integration as with a B&O TV? All I can find is that you have to buy a separate WiSa transmitter for LGs 'WiSa compatible' TVs. I'm not talking about B&O TVs, those are too expensive for me.
The latancy of the beolab 17 is 4,4ms or 1,51m. You need a device that can handle that.
So the Beosound Core is my best bet?
The Core has no Wisa, so you’ll need an external Wisa transmitter in all cases if not integrated in your TV.
Thanks. But I can use the Lab 17s just with the Core right? And then use optical to my TV?
Yes you can, I do this with a Sony tv connected with toslink to Beosound Core/Beolab 17
I recommend one of the following setups for your TV:
1. Beosound Core + Beolab Transmitter
this works very good if you have more than 2 speakers (up to 11). I use it myself with 5 speakers with a Samsung TV.
2.  System Audio Stereo Hub
