Beolab 14.4 with Beolab 7.4
You use the 7.2 for listening to music?
In any case, BL14 has no outputs per-say. The only outputs go directly to the satellites,... but they are amplified at that point, and that output has also gone through processing specifically for the satellite driver.
The BL14 would be connected directly to a pre-amp, as would your BL7.4.
Bought the apartment today 😎
Congratulations from here too!
Hopefully with room for your experiments.
Don’t you have multiple BL7-4s from a previous setup? Why not reverse the roles and use the 7-2 as front centre, with 4 x 7-4 for front and rear L/R? Hook them all up to the Almando 5.1 surround processor?
Bad idea! The 7-4 is tuned significantly different from the rest of the 7s. I have actually tried it out, does not work!
BUT,- if you have used the 7-4 as centre you will never be satisfied with the performance of the 7-1,2,6 in video mode.
That being said I absolutely love the Beolab 7ens, by now you will know why! 🙂
I’m a convert! And toying with the idea of a 7-6! 😎Bad idea! The 7-4 is tuned significantly different from the rest of the 7s. I have actually tried it out, does not work! BUT,- if you have used the 7-4 as centre you will never be satisfied with the performance of the 7-1,2,6 in video mode. That being said I absolutely love the Beolab 7ens, by now you will know why!
