Beolab 14 satilite speakers
Good afternoon all,
im hoping someone on here can help me with accessing the wiring ports in the satilite speaker? No do out this is a simple process but I can't work out how to open the rear of the speaker (well without damaging it).
You are not supposed to open the back; instead, you need to remove the fabric cover from the front. Then you can access the speaker connectors.
Human interface designer at Bang & Olufsen.
Thank you for your help with this! Is there an easy way to remove the fabric? It seems ike prising the cover off may damage the aluminium.
Rotate fabric and remove.
