Hi Forum
I have recently bought a secondhand BeoLeb 14 5+1 setup. It seems to work perfectly fine in terms of the sound, but there is no light from the LED at all. I guess the LED is the white thing in the bottom of the subwoofer module?
I am using a Denon AVR-X2000 surround receiver, with a high level for the satellite speakers, and pre-out for the subwoofer. I have ensured to switch the input selector on the BL14 subwoofer to AMP.
I really miss the LED, to ensure that the amplifier for the subwoofer is switch off after some time.
According to BeoWise it should take 3 minutes after no signal. But let's say there is too much noise on the cable, then the BL14 will always stay on.
Is it common for the LED to fail? Do you think it is still possible to deliver the subwoofer to a B&O Dealer for repairment of the LED?
