Hi All, i am new to the forum and looking for some advise on a new living room setup I am planning. My AV knowledge is minimal so any help is much appreciated.
A few years ago I bought a BeoLab 14 setup which I would finally like to make use of. So what I want is to creat an Atmos setup using these speakers. I have some canton 880’s which is ideally like to use but I would consider buying some beovox 2-2’s if they are recommended. Anyway, the advice I need is which AV receiver would work for my needs, I’m looking to spend around £500 and have been looking at the denon AVR -X3500H, I believe all speakers plus are 8ohms, which the denon supports.
would the denon be a good option for me? Should I change the ceiling speakers I have? Any help would be much appreciated before I make any costly mistakes.
thanks in advance.
