After faffing around working out where best to position the rear satellites, I have decided on a position and worked out how to use existing pictures on the wall and a mirror to hide the cables. The dealer has two satellites in stock which is good news.
Just a question about connections. I currently have the 2.1 set up with the following:-
1. Powerlink cable running from the TV's Front Powerlink socket to the Front Powerlink input on the sub.
2. 2 x RJ45 speaker cables running from each front satellite to the corresponding speaker input on the sub.
I do not have anything at present connected to the TV's Subwoofer Powerlink socket. This is not being used. The only connection to the TV is via the Front Powerlink input.
When I attach the two additional satellites, do I simply need to connect the Beolab sub to the Rear Powerlink input on the TV (as well as connecting the satellites to the sub) or do I also now need to attach the sub to the TV's Subwoofer Powerlink output as well?
Any input gratefully received!
C
