vox wrote:
Hello,
I want to buy new speakers, which need not be connected to a television.
In my selection are the Beolab 3 or Beolab 12-3 in connect with the Playmaker.
Which Speaker have better Sound ?
Has anyone of you heard the two speakers have a direct comparison?
This to me was unfortunately not possible with any of the vendors.
I like doing both.
I want the speakers on the floor stand (20cm - 30cm away from the wall) place.
Wall mounting is not possible.
On paper, yes should the Beolab 12-3 (pure data to) be better.
Would be nice if I could be your buying decisions to help.
Thanks in advance
With respect to measurements, the 12-3 would have to be significantly ahead to make an audible difference.
On the other hand, as you are intending to free stand the speakers, IMV the spherical shape of the Beolab 3 will offer an distinct advantage in terms of being free of a flat baffle, which in the case of the 12-3 will add standing waves reflecting off the baffle to sum with the direct sound output of the main drivers, which will increase the coloration/distortion overall; you would most likely expect a considerably more spacious sound from the Lab 3's with better sound-staging and imaging, simply because of the cabinet shape and the way you intend using it - free standing - as against wall placement where the advantage of the sphere would be ameliorated to a degree by the proximity to the wall.
So, IMHO if you were wall mounting, I'd go the 12-3, but for free space/stand mounting, I would go for the Lab 3.
But as always, things such as the aesthetic look etc will come into it; either way they are both excellent active speakers and I can't imagine many people being unhappy with either of them.
Hope this helps & good luck with the decision
Kind Regards
John...
