I am thinking about buying a pair of Beolab 12-3 as you can find them quite cheap nowadays and I like the aesthetics. However, I have not heard them up to now and would like your opinion on the sound wise. I found a few old posts on here but it seems that the speakers did not sell well and therefore there are not many people discussing them. What would you pay for the Beolab 12-3? Would you get Beolab 3 or Beolab 12-3 if you had the chance?
Beolab 12-3: Buy or not?
As for design ..you should go for BL 12.3
But only wirh wall mount.
Sound is not so much better then Beolab 6000 or 8000.
But better than Beolab 3.
Sorry nice littel speakers but not as good as some of people say.
Fine fo rear speakers. or front with sub.
I konow as i have all of them.
In my living room i have BL12.3 with custom made sub with range from 20HZ and if i can say it's just as nice soud as BL20 or better.
How can you rate the bl3 under a pair of 6000 !!!
I loved the look of these speakers, and was prepared to buy them new. I’m so glad I auditioned a pair at a B&O dealer before doing so. I was very disappointed with the midrange - cold-sounding. The dealer did a back to back demo with some BL18s and the 18s wiped the floor with the 12-3s.
I strongly recommend that you listen before you buy.
How would you say they compare to Beolab 3? The Beolab 18 are in a different price range.
I’ve only heard a BL3 in passive listening, so I can’t honestly compare their performance.In price terms, you can find a pair of BL3s for around 800 GBP on eBay, whereas a pair of BL 12-3 will be twice the price.If looks are all-important, go for the 12-3 AFTER hearing it.But my money would go on a pair of BL3s with a BL2. Together these would still be slightly cheaper than a pair of BL 12-3s, would look great, and the depth of bass would be astounding (I have a BL2).How would you say they compare to Beolab 3? The Beolab 18 are in a different price range.
BL 6000 are very fine sounding speakers and cheap...very easy to repair.
Only error of these speakers are rubber roundings on the drivers. Repair costs 30Euro.
Beolab 12.3 are one of the best B&O looking speakers if they are on the wall.
During past 2 years i heve some probems with resonance in the speakrs. ( 50-80HZ )
And sorry to say i'm not the only one with that problems.
On the same place as now BL12.3 i heve many years BL4000 with no problems at all.
I still say that BL4000 are one of best ever made.
Just one day ago I was fortunate enough to be able to test directly at my house to listen to both the Beolab 12.3 and the Beolab 12.1. As far as I am concerned the 12.3 are significantly higher, although the clarity of sound does not repay in live sessions... The 12.1 have a more obvious sound that makes better the characteristic sound, for example, a live session of jazz... I still chose the 12.3 Even for an aesthetic factor because I find them wonderful. Obviously in the range of my spending budget! will match them to a BeoSound 5. As soon as I can I will buy a subwoofer (I was thinking of the Tulip...)
