I noticed the silver covers on the side are connected by a cable that connects to the main body. I removed one of the covers and also ended up detaching the cable of the cover from the body.
Question is, does the cable have any function?
Earthing, I think.. 🙂
Thanks. Not sure if it is a placebo or not, but looks like some distortion at high volumes I had before is gone once I attached it. May be I moved something around that was touching the speaker cone...🤷🏽♂️🤞🏼
