After a few months since it was launched I was wondering what is your opinion about the Beolab 11. Specially if you have heard or own one.
Beolab 11 opinions
I'm waiting for mine to be delivered. I had the chance to hear it and I think it's ideal if you want to just boost up a bit the bass.
Of course it is not Beolab 2 so I guess that Beolab 11 should accompany certain speakers that already have some certain good bass level. I would say that it gives exactly what would be missing.
On the other hand I think it's a matter of taste in the sound and how everybody wants to hear their favorite music!
mine was installed on Tuesday this week in connection with 2 brand new BeoLab3.
As of the short time of installation I would not point out a final decision or final review of my installation but right now I would judge the BeoLab11 as the perfect extra boost for my installation.
In more silent situations you hear the little extra from it but if you turn on some more volume you can actually feel the bass.
In case of some more questions please let me know.
The BeoLab 11 is perfect for BeoLab 4000 and 6000. I have a switch attached to BeoLab 11/4000 and 6000 combinations in my store and the difference is very apparent...
we have had ours for 2.5 months now and love the richness it gives to our listening
not obvious as a subwoofer - very subdude
we have it coupled with 2xBL3s
This is exactly what a subwoofer should do for music. Music was recorded for stereo speakers - left & right. If you can hear your subwoofer, then you're hearing three speakers, which isn't right!
Subwoofers are only there to make up for the shortfalls of loudspeakers. If your speakers struggle reproducing sound at 50 Hz, then you need a subwoofer to give them a hand. If your subwoofer is sat in the corner booming away constantly, then there's something wrong, either with the subwoofer or the way it's set up.
I've been very impressed with the BeoLab 11 on the occasions I've heard it - really adds a lot of depth and weight without bogging the sound down in OTT bass (unlike certain other subwoofers).
Hi Alex :)
I was not complaining !
I was commenting ... we like it, although our son-in-residence was looking for more *doof* *doof*
However with the right movie at the right volume you can get the effects :D
I've been using the BL11 since the week it entered the shops. I added it to two BL6000's and I'm still going completely wild each and every day. The bass is so incredibly ... well... GOOD! Not loud, but good, accurate, fast, perfect for music. It took my BL6000's right into the 21st century and hasn't let go ever since.
I've long thought about replacing my BL6000's with BL9's, but I just don't like the design of the 9's and LOVE the design of the 6000's. The addition of the BL11 to the BL6000's has settled the problem once and for all: I can listen to this combination till the day I die. The 9's will not enter the house, thanks to the BL11.
I'm not trying to say that the BL6000/BL11-combination sounds better than the BL9. Not at all. But it's made the gap between the BL6000 and the BL9 a WHOLE lot smaller. Because not only it adds bass to the 6000's, but it kind of 'releases' the 6000's to play like true stars.
Funny thing: half of the improvement is in the HIGH end!
Can't recommend the BL11 enough, if you're using 4000's or 6000's.
where did you place the BL11 ? as recommended midway between your BL 6000s ?
