BeoLab 11 hands-on
Hi all,
Today I dropped by my B&O dealer and low and behold, the BL11 was just in! The dealer was kind enough to hand one over to me so I could test it at home. I'll have to return it on Tuesday, but I guess I won't. The only thing he's going to get on Tuesday is my payment, because WOW what an improvement this is!
For your information, I'm using a BV7 with BL7.1, BL6000's as front speakers an BL4000's as rears.
The first thing I noticed was that I didn't really notice the sub at all. But what I DID notice was that my BL6000's sounded like they never, ever did before. I never knew their midrange and their highs were so good. In fact, they never were, until I connected the BL11. The soundstage has improved a lot as well: instead of one wall of sound, which the 6000's usually produce, all instruments seem much better placed  now and much better to discern from each other.
I expected a sub to be a huge improvement on the lowend, but the greatest improvement seems to be on the mid and high. Weird.
But now, about the lowend. The BL11 definitely is not a vicious thunder cloud. But... what it IS, in my opinion, is a bass producer with laser precision. Bass tended to be kind of a mess on the BL6000 (on some songs, like George Michael's Freeek, it was just a bunch of rumble). The BL11 does a much, much better job. Bass really is razor sharp, but not thunder strong.
I also watched one movie tonight, James Bond's Casino Royale, and in this mode (speaker 5) effects where the same as in speaker 2 for music. Much better placement of all sounds, bullets flying through the room with a lot more precision than ever before.
The overall feel of the addition of the BL11 to the set described above is, that the music just flows out a lot more naturally. The BL6000's seem to be tired to play the music, while with the added BL11 they're a lot more happy, and so am I πŸ™‚.
Finally, a test I did was the following. Sometimes I used to switch from speaker 2 to speaker 1 (so using the BL7.1 instead of the BL6000) and sound always was a huge improvement on the high-end. No doubt at all. Now, with the added BL11, this is not the case anymore, by far. The highs are comparable. But the BL6000+BL11 combination does sound a lot better on the mid and low-end.
So, to summarize: the BL11 breaths an incredible lot of new life in the BL6000's. It won't add the big thunder boom, but it does improve sound on the complete spectrum to a level which I never thought possible with the BL6000's.
And even the wife likes its looks!
100% recommended for 'smaller' speaker owners.
Always a good thing.πŸ˜•
CraigπŸ™‚
Thanks for the nice write-up! The BL11 sounds like a winner!
I'm from France and I would like to buy the beolab 11, for completing my beosound 4 and the beolab 3. Do you think it's the good way ?
If your room is not to big a say go for it..πŸ™‚
An interesting review, thanks!
You say that the Beolab 6000 play "lighter and happier" with the Beolab 11 connected, to:
Is there a crossover in the Beolab 11 which cuts out the low Bass-Frequencies from the Beolab 6000?
If "yes" I'm finaly gonna invest in a digital crossover from "Behringer" Studio Equipment to adapt my active subwoofer to the Beolab 6000. Actualy I'm using it with a Powerlink-RCA-Connector from the 2nd Beolab 6000 to the Subwoofermodule and that means that there's no electronicaly cutoff for the 6000.
That would be good news :-)
Well, mine is connected to the subwoofer out on the BV7. So the BV7 handles the frequencies. In the BV7 menu I select 'subwoofer: yes' and I guess that then the BV7 decides to send the low frequencies to the subwoofer and not to the BL6000 anymore.
After a day I'm still extremely happy with this setup BTW 😁.
I would be interested to hear what it is like with music - and in particular, is it directional? Can you hear where the Beolab 11 is? The upper frequency is very high for a sub-woofer, quite a bit higher than even the Beovox Cona which certainly is directional and requires careful placement.
I've got a question for the group:
I'm about to get a BV-7 55" (I've been waiting to redo some cabinets to fit the TV first).  I'm going to get the BL 7.6 with it.  My only regret is that while I'm going through the expense of redoing the cabinets and paying for an expensive TV, I sure wish I was upping the ante in terms of my speakers which are BL3s.  I've decided to probably not use the BL3s as the BL 7.6 seems pretty equivocal to me and I probably can't afford BL 9s or figure a way to incorporate them in to my cabinetry.
Here's the question for the person with a BL 11 hooked up to a BV 7:  When listening to music, would BL 3s with a BL 11 be a significant bump up from the BL 7.6 (i.e. if I had this speaker arrangement hooked up in addition to the BL 7.6 but just used the arrangement for playing music)?
TIA,
Mark
@Peter: I don't notice where it's located. At least, not with my eyes closed πŸ˜•. But I guess in the end that's something you really will have to test for yourself in your own home.
@Mark: Personally I found the BL7.1 (which I guess is more or less equal to the BL7.6 except for size?) not capable of producing great music, except for electronic music. I've never heard the BL3's, but I guess that even without the BL11 connected to them, they should be better for playing general music compared to the BL7.6? I know my BL6000's are, and they're supposed to be of lower quality than the BL3.
I don't know if the BL11 will add much to the BL3 because, again, I never listened to the 3's. I can only judge my own arrangement and while listening to it tonight, I got all kind of metaphors in my head... but let's just say the BL11 reminds me of anything that's good and tight 😎. Really, I absolutely completely love this little egg...
