BeoLab 1 Column Dimensions
I'm wondering if someone knows (or could measure) the dimensions of the column of the BL 1 speaker. I can only find the height and the diameter of the base. The column appears to be (sort of) ellipictical in cross section. This is the measurement I need.
Cheers
Stuart
Hi Stuart,
I just measured mine: 17.2mm from side to side and 14.5mm from front to back.  Let me know if you need any other dimensions.
 s.
Exactly,
17,2 and 14,5 are in centimeters, and the both straight (flat) sides of the cross section are 8 cms each.
Regards.
