Beogramm 7000 -> Beosound5 (+Master)?
How to connect a Beogram 7000 to a BeoSound 5 inkl. beomaster 5 so that you can listen to the beogram also in the link rooms and control it with the beo4 reomote?
THANKS!
Just have a look at Steve's website (soundsheavenly), he has the solution for you..Look for "BeoMaster 5 aux." 🙂
Nio wrote:
... so that you can listen to the beogram also in the link rooms ...
Possible if BeoMaster 5 is the audio master of your ML system.
Nio wrote:
... and control it with the beo4 reomote?
As the BM5 has only an USB and no DataLink enabled input, you will not be able
to control the turntable by a remote - only manual operation possible!
As already mentioned by Chris, you'll need some parts from Sounds Heavenly:
- an analogue <> digital AUX input converter
- and an adaptor cable to connect the DIN 7pin (BG7000) > 2x RCA/Cinch/Phono (converter)
Ok, thanks ... So if a buy an overture for example I can connect the BeoGram with Dtalink to the overture and the Overture with masterlink to the rest of the system.
Version 2.1 can be a slave even in the main room and I can listen to beogram in the linkroom?
