How to connect a Beogram 7000 to a BeoSound 5 inkl. beomaster 5 so that you can listen to the beogram also in the link rooms and control it with the beo4 reomote?
THANKS!
THANKS!
Just have a look at Steve's website (soundsheavenly), he has the solution for you..Look for "BeoMaster 5 aux." 🙂
... so that you can listen to the beogram also in the link rooms ...
... and control it with the beo4 reomote?
As the BM5 has only an USB and no DataLink enabled input, you will not be able
to control the turntable by a remote - only manual operation possible!
As already mentioned by Chris, you'll need some parts from Sounds Heavenly:
- an analogue <> digital AUX input converter
- and an adaptor cable to connect the DIN 7pin (BG7000) > 2x RCA/Cinch/Phono (converter)
Ok, thanks ... So if a buy an overture for example I can connect the BeoGram with Dtalink to the overture and the Overture with masterlink to the rest of the system.
Version 2.1 can be a slave even in the main room and I can listen to beogram in the linkroom?
