Both motors spin, the platter spins. Using the play button, the platter spins for about 5 seconds, the tone arm just sits there, and then it shuts down.
Manually, I can rotate the gear just behind the platter axis (driven by the gear on the platter). If I rotate it full circle, the tone arm moves to the left, then back to the right as it is supposed to do.
I have cleaned up the white lube on the tone arm guide rods and lightly lubricated with white lithium grease.
I applied oil a couple of places in the gear train. The pulley that has the wire belt on it, I removed the C clip and applied oil, moving the pulley up and down on its shaft. I did this because it felt a bit tighter than the plastic gears.
I am at a loss, any guidance will be greatly appreciated.
Steve
