Beogram into 9000?
I have hooked the two up with the DIN cable from the turntable into the 9000 socket but I have to turn the speakers up really high to hear anything.
Should I be using the turntable in this way or do I need a pre amp between them?
Cheers
Glenn
If by 9000 you mean a Beocenter 9000? Then the answer should be no as long as it is connected to the Phono input. If it is a Beosound 9000? Then yes you will need a Pre Amp.
CraigπŸ™‚
Many thanks Craig.πŸ€’
Can anyone recommend a Pre Amp? I see that there are battery powered units and mains units.
I plan to upgrade the turntable to something that equals the performance of the speakers later so probably not the battery model?
Many thanks
Glenn
