Normal 0 false false false EN-GB X-NONE X-NONE
Hi Everyone,
I recently acquired BeoGram CD 6500 and now I’m checking its functionality. Fundamentally unit works which is good. There are two things that I would really appreciate input of someone who owns such equipment or ever went thru its functionality checks and adjustments.
- CD drawer
close automatically after just few seconds. Bassically once CD draver is open
it stays open only for 3..4 seconds and automatically close back. This is a bit
annoying since it leaves operator very little time to change CD itself. Below
are short clip where I try to show the problem.link I checked end switch and in my opinion it works as expected. Again
little clip here to have a look: I also checked signal on collector of phototransistor on PE201. I can
see pulses when drawer moves in or out so at least pulses are generated. I didn’t
go any further with my debug here. If there is someone who came across similar issue (assuming this is
issue) and found a solution to it I would greatly appreciate hint on it.
- Following instructions in mechanical adjustments I attempted (using eccentric screws B and C) to centre drive mechanism and centre bracket for disc clamping magnet. I have to say I actually have a hard time saying when things are correctly adjusted and when they are not. What should I look for when performing those adjustments. With whatever I do I still see magnet landing a bit out of centre and then during CD spin wobbling a bit. Little clip to demonstrate it here: link Is what I’m seeing here a problem or is it normal operation of properly working CD mechanism? Should I expect magnet landing exactly in the centre of CD or a bit off the centre is fine?
Thanks in advance for your time and help.
Cheers,
Henryk
