I just purchased a Beogram 8000 that's nearly new old stock from the original owner that had stored, and never used it since new.
it worked flawlessly initially but after a short while the tone arm won't drop. The servo belt is intact but appears to have slack and a new one is on its way. My question is twofold:
1) How do you gain better access to change the belt. I've removed the black cover that sits under the tone arm but there's no easy way to get at the belt.
2) Would a loose belt cause the tone arm to not drop? If I tap it, it will drop onto the album... Almost like it's just a little sticky (seems released but just not dropping on its own).
Thanks in advance,
Larry
