Beogram 7000 Tone arm does not fall far enough on the record
I recently bought a second-hand Beogram 7000 with an MMC2 element. When you press on start, the tone arm goes neatly above the record, however, after it has fallen on the record, I have to give a little push to the tone arm, then I hear the sound properly. If I don't do this little push, the sound sounds awful. It seems that the tone arm sticks.
Does anyone have an idea?
Thanks.
Best regards,
Bertus Toering
Does it play the whole record ( fully ) or stops earlier?
Sounds like bad cartridge suspension
Hi all,
I was  a bad MMC element.
I have already sent two elements to for repair:
link
Neatly repaired and a quotation in advance. I have now had two elements repaired, MMC4 and an MMC5. Done perfectly.
Best regards.
Bertus Toering
Hi Pat,
When I help the tone arm a little bit, it plays the whole record (fully).
The sounds is then excellent.
Hi Pat,
Hi Pat,
Thanks, I buy a new MMC2 element.
Saint Paul,
I was a bad cartridge suspension. Yesterday I received a MMC2 element and the sound is perfect.
Thanks.
Thanks for reporting back, enjoy!
