Beogram 6500 : MMC5 needle missing ... what do do ?
Hi all, I recently picked up a Beogram 6500. It was stated as "non working"
I checked everything : the belt is a bit loose, that's an easy fix.
But I saw that the MMC5 is missing the needle itself, the tip, I think it might have broken off.
See pictures ;)
What can be done to fix this ? or is it better & easier to buy a new needle ? Whereabouts can you get these ?
Hi.
Your MMC 5 can be refurbished, price DKK 999,-
Contact: pickupservice@outlook.dk
Regards TECHHN
Many thanks TECHHN, I have sent an email ;)
I've ordered a new belt too, would be a pity to have such nice record player go to waste :(
Hi.
I hope you have ordered belt set from "Dillen"
All others have the wrong elasticity.
Below you will find different types of repairs available for MMC 1 to 5.
(S)MMC 5, 4:  A newly developed enhanced elliptical diamond, made in Switzerland. DKK 999, -
(S)MMC 3, 2, 1: CL diamond, sapphire Cant. DKK 1,750,-
(S)MMC 3, 2, 1: Original Shibata diamond, alu. Cant. DKK 2,375,-
See pictures ;)
hello, you can repair this MMC5,
Have a look at the site from F-J-S  (Franz-Josef Schulte) at :
