I got a Beogram 5500 record deck with issues.
The arm does not move this is likely a carriage belt I will open and check.
The bigger problems are the Beogram 5500 is unresponsive to my Beolink 1000 remote which works on the Beocenter 9500 and all the other 5500's. It is also unresponsive to the master control panel.
Also there is no sound coming out of the Beomaster 5500 amp even when i put the arm on a record and lower the needle using the play button on record deck. I can hear sound when i put my ear next to the needle but nothing comes out of the speakers or amp.
Does anyone know how to fix these issues?
One thing I must add nearly every audio B&O purchase of mine from ebay has been full of problems and headache!
