Hi there,
I’ve put myself under a bit of pressure as it’s the wife’s 60th this year and she’s arranged a bash at home, with a fair number of guests turning up. The invites included a note to “bring some vinyl as Richards getting his deck out (referring to my Beosystem 5500). So having spent 2 years redesigning the garden I’m now under pressure to get my Beosystem working. Dug it out last night (not been used for a fair number of years). As expected there’s a number of issues!
Beogram CD5500 powers up, draw won’t open but if CD inserted it seems to read and move between tracks. Connected to my Beomaster 6500 (had front changed to Beomaster 5500 by dealer when bought new as I wanted powerlink) no sound, slight sound if you turn up to high volume. Same if you connect to Beomaster 5500, which I also have had from new. Radio seems to work o.k. on Beomaster 6500.
Beogram 5500 turntable same issue with Beomaster 6500 but works with Beomaster 5500. The playing tone arm was flashing 33 but has stopped but don’t know why.
Beocord 5500, have two of these. One the draw opens o.k. even had a tape still in it and it played o.k. The fast forward was a little slow. The other one powers up but draw tries to open but won’t. Suspect it might need belts.
Beolab 4000, have two pairs of these but only had time to try one pair, of which only one speaker power up, the other is dead. I know these have a foam rot issue and I’ve not checked this yet. These have hardly had any use.
I’m trying to contact “Dillen” for new belts as he seems to be the go to man for these. Any other pointers or help would be greatly appreciated.
Having had all units out in my dinning room I’m of the opinion that the Beomaster 6500 seems omit a electrical type smell, not a burning type smell but it definitely has a smell about it.
I’ve also got a Beosound 9000 which seems to have issues moving between CD’s and the carriage drops to the bottom (it’s vertically mounted). Once up and running it seems to work o.k.and suspect the lack of regular use might be a factor.
As a back up I’ve bought a playmaker from a dealer, just need to sort out how I connect
Many thanks
Richard
