Hello everybody, I'm new to Beoworld, I have a recently purchased a Beogram 5500 the Din plug has been cut off and I wish to put back to standard my problem is that there are five wires Red/White/Yellow/Blue/Black and the shield, can anyone tell me which wire goes to which din pin I have been unable to read the schematics (lack of knowledge/understanding) I wish to connect it to a Beomaster 5500 Any help would be very much appreciated.
Beogram 5500 DIN connection
Hello,
I will try two help you.
OK, you need a 7-pin DIN plug!
In this thread ist noticed how two solder the wires
https://archivedforum2.beoworld.org/forums/p/19979/164930.aspx#164930
In your cable is a blue and a 2nd white cable that are not used!
Two find out wich white kabel is conected you must open the beogram two look for!
Not be confused if in other threads Beogram 9500 are named, they are technical identic to the 5005
Gold luck
Thank you so much for your help Wilfried, I can now bring this turntable back to life, I have already repaired the drive wire lug thanks to this forum. best wishes Russ
