Anybody point me in the direction of where the wires are soldered in the DIN plug? Dying to see if a resoldered plug solves my issues.
thanks
Beogram 5005 DIN 7 wiring diagram
Hello,
only the standard cables MASTERLINK (8-pin) and DATALINK (7-pin) are described on the BEOTECH side!
The beogram connection cable is somewhat differentiated
please have a look at the thread
https://archivedforum2.beoworld.org/forums/p/39007/297772.aspx#297772
there I described the connector of the Beogram
the thread is partly in german, but google is a good friend here (translator)!
I took the DIN from the cd apart and copied wiring - bingo, worked a treat.
thanks for taking the time to help reply.
derek.
