The tone arm on my Beogram 5000 hits the record a few mm to far out, i.e on the blank part of the record.
The manual simply says:
"Adjust the eccentric N until correct 30 cm touch down point."
"Adjust with arm P until correct 17 cm touch down point the eccentric N until correct 30 cm touch down point."
- Is eccentric N the small screw behind the tone arm? See picture
- Are these two settings fully separate? So since I won't be playing 17cm records I can just leave it as it? is?
