Hello dear Boeworlders,
I bought a used and damaged Beogram in Germany and as I love B&O and need a new turntable I thought I'll make a complete restauration. In this thread I will post all my experiences on restaurating this old turntable from the 1980's.
From the first look I can say the Beogram ...
- .... has a problem with turning and moving down its tonearm. I think this is a problem that can be solved very easy
- ... is in need of a new needle. Any recommendations? I would like to have the best possible needle.
Restauration steps:
- removing all visible parts
- cleaning all visible parts as all materials seem to be oxidized
- checking all mechanical parts and change belts etc. for new ones
- cut all wires and equip the Beogram with a c8 or c14 socket and mount cinch terminals
- rebuild the lighting with LEDs (warm white)
- rebuilding everything and final ckecking
I will post all my experiences and tipps and tricks in this post. If someone has a service manual for the Beogram 5000 this would help a lot.
I would also need tips for the best needle for this beautiful Beogram.
