I thought I would share my thoughts in case my experience is helpful to anyone.
I have a Beogram 4002 with MMC20EN and Linn LP12 with an Rega Exact Cartridge.
I love using the Beogram but had it stuck in my mind that it cannot be better than the LP12. Due to a move I've had to pack away most of the B&O stuff including my M100 speakers, but kept out the turntables and a small valve headphone amp. The problem I have always had with using the Beogram with non B&O amps is the slightly low output from the cartridge - it obviously works fine with B&O stuff. Interestingly it worked fine with my Quad 303, but was still just slightly low and I'm looking forward to hooking it back up into that system and comparing the iFI phono stage with the Quads.
The HifI world seemed to be going mad for the iFI Zen Phono preamp so I bought one as it has variable outputs. I have to say it's the best phono preamp for the money that I've had for my Beogram. To compensate for the low output I switched the input to MC High Output - which is recommended for cartridges at 2mv - the 20en is 2.1 I believe and for 47Kohms so it should be matched. This was really successful and it sounds far better than the MM input which makes it sound quite and a bit warm. In fact it's the best I've heard it - everything is really clear. There is a subsonic filter with what they call AI and it's supposed to only filer out rumble - I have this pressed in as well. Surface noise is very low and the whole thing just seems to sing. I tried the Linn afterwards and to me, I much prefer the sound of the Beogram now, somehow just seems more lively and clearer.
For £150 on amazon it seems a very good value for money answer to using a B&O turntable with a non B&O amp or newer B&O equipment without a line level in.
Has anyone else tried this amp? or found another phono amp worthy of recommendation?
