Hi both, thanks for the advice. Really appreciated. Thanks for the links too
Just to recap I had a fully working 5514 and wanted to use the main board to get the damaged 5524
Working agin, while I fix/ replace the original main board. When adding a new IR LED to the arm position and arm position IR photo-resister, It caused some unknown problems.
When adding a visible LED to the it illuminates and now luckily When I press the start on either the turntable with a strong light overhead and turn it off the arm drops. If I shine an LED torch or phone torch near the sensor it drops and likewise if I shine at the end groove of a 33 it will lift and return to the home position. Less light is needed on the 45 for it to lift and return to the home position with light shone near the sensor.
*The sensor at the base of the tonearm doesn’t seem to work on the 5524 as the motor doesn’t move as it should when a record is played.
So with this is mind, does it appear that I am using the wrong LEDs to activate the photo sensor or maybe there’s there a damaged transistor or resister not allowing enough power to get the arm position sensor. I don’t have a stroboscope and have basic ability with the voltmeter.
Does anyone have a link or a known supply
A. for replacement sensor at base of the tracking arm?
B. Suitable replacement arm position sensor?
Thanks again
