Thanks for the reply.
Unfortunately I don't have the original motor. I bought the turntable on Craigslist with full disclosure that the motor didn't work. The price was greatly reduced so I thought I'd give it a shot.
What I found when I opened it was a DC 3V motor with model number MHN-3P2RDB. At the time I didn't realize this wasn't the original motor. It wasn't till later after browsing these forums that I made that discovery. Although it is a 4-conductor motor, it was modified to 3-conductor. In addition, it was incorrectly plugged into P2, not P1.
After changing a blown fuse and plugging into P1, it did run, albeit for a short time. After about a minute, the motor slowed until it stopped and no longer works.
Any thoughts or ideas? Can I manually test the motor with an external power supply? I used a DMM to read the voltage at connector P1 after I press START and got no readings, ie 0 VDC.
Thanks in advance for any help.
John
