Good evening forum!
I recently aquired a BG 4000 for very little money ! Planning to follow Menahem's repair & restoration project via his Website.
The BG is in remarkable external condition for 40 yrs old. I knew it had some mechanical issues.
Wood frame 9/10, Acryilc Cover 7/10, Alu 8/10, Platter 9/10, Base 10/10, Cables 10/10, MCC 20EN near perfect , just crudded-up with dust.
The BG powers up with a strong relais-click via ON button. Platter turns. Tracking-arm projects light and displays B&O Logo in red. Pressing the "west" Arrow-Button gets the Tone-arm moving toward center. The stroboscope seems to perform.
Now for the bad news: The tone-arm won't lower when the "South" arrow is pushed. The STOP button must be held patiently down while the Pick-up travels slowly to the right. BG only switches -off when arm is parked on the extreme right. The "East" button has same effect as stop button (Arm travels right and parks) The 33/45 Red bulbs don`t Illuminate - ever. The Scale & Cursor don't illuminate. The 33/45 Alu-Rocker-Switch seems to be stuck in 33rpm. mode and has seemingly no function when either speeds are selected. None of the automated play functions work as described in the Manual.
I have dismantled the Alu-covers according to Service-Manual, and checked for visual anomalies on the mechanism and PCBs under the Controls. The general internal condition is very original. I think this BG was very seldom worked-on. Screw-heads are neat. Sealing-Wax is still in-place. The copper-Springs holding the Alu-Controls sit nicely, and hold the Alu-plates in-check. When pressing the various functions, one hears a faint Click as the contacts meet.
I have carefully oiled (Sewing-machine oil ! ) all the pivots, solenoid, copper damper etc just as suggested by Menahem. To no avail !
I really don't want to junk this unit, so I'm hoping that someone on the forum with the know-how can post some hints on where to start and which components may be culprits. I'm really hoping too that Menahem could pick his brains, as I'm sure he's been thru this more than once. I have good tools, solder-station, magnifying equipment ( and some patience left). I just don't want to meddle-around, trial & error, and do more harm than good, or roast the unit.
Thanks for reading and for any considerations
Cheers
Zorb.
