Hello,
I just got a beogram 4000, my problem is that without a disc placed on the tray the arm stops then descends as if there was a 33t on the tray, ditto if I place a 45t the arm stops as if there was a 33t.
the next day, I heard a sizzling sound from the side of the power supply when I pressed ON, and since then it does not light up at all.
The fuses are good.
Thank you in advance for your help.
Beogram 4000 does not light up
