Normal
0
false
false
false
EN-GB
X-NONE
X-NONE
Thank you for the response to my request. I have been
through a whole process of suspicions before I arrived at the tracking
possibility. It all started when I bought a reconditioned cartridge from FJS in
Germany, and I found that there was a problem with the sound on one channel –
my first reaction was that the cartridge was faulty, but after speaking to a
few people I realized that it could be due to other things, e.g the tracking of
the tonearm. I cleaned the slider bar for the tonearm and regreased it, and
found that I had sound on 2 channels( although the sound wasn’t perfect). When
I tried playing a few records I found that some of them played all the
way through and some had a problem with the tonearm sticking. It seemed that
the longer the playing time( and therefore the less the spacing between tracks)
the tonearm was prone to sticking. It seems I need to adjust the optical
system, but until a week ago I didn’t even know how the tracking system worked.
So I need some advice on how to go about checking the tracking and how to
adjust it. I have seen that when the stylus sticks, the pıckup arm is not
tracking.
As for all the other points you mention –
yes, I have checked all of the obvious things.
It seems I need a special test record to
set up the tracking properly, but I don’t possess such a thing, nor is it
possible to obtain one, as far as I know. If you can indicate how I can set the
tracking without the disc, my immediate problem will be solved I think.
Many thanks once again
Alan
