Normal 0 0 1 178 1020 8 2 1252 11.1539 0 0 0
Hello I am new member / is there anyone who can help me to solve a problem with my Beogram 4000.
I own it almost 2 years and it was in good working condition a year ago . I did not use it for a while, a week ago I decided to use it as my main turntable. I start it up push the start button nothing happened. after a few seconds it went off. Tryed again, the same . Opened the deck checked for damage loosen wires etc. putting a new small belt on the slide driveshaft an push the start button again, nothing, same as before, then pushing the start and the left arrow the slide and the arms running back and forwards when I keep pushing the left arrow button the soon as I free the button it runs automatically back and the power gets off. When it’s on and running like described above and push the off button nothing, the up and lowering button for the arm is also not responding. the arm goes up and down when I push the piston handle by hand. The spindle also makes a sound as a car wheel without a bearing. This I suppose is a easy to solve mechanical problem – the start problem could be a electric or contacts. hope somebody can help me out /gi advice etc. to get this beautifull turntable running smooth again.
THX! . Barn
